Discussion topic: Pair a remote
This message was authored by: Sophielegs
Pair a remote
How do I pair a new remote please
Re: Pair a remote
hi @Sophielegs
Even though it is new may I suggest you do  a reset of your remote first.
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Either way to  pair:
Press 1 & 3 together to go through to pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
