Discussion topic: PIN number problem
This message was authored by: JPember99
PIN number problem
We can't access certain channels as its pin protected
. We have tried to put the PIN number in but it keeps telling us to check the connection. Should we have the q box connected to the phone connection.
Re: PIN number problem
Exactly what message are you seeing and what are you trying to watch @JPember99
Avatar for JPember99
Sky witness and showcase
Theres a problem with your connection.
Please check your sky viewing card is inserted and your sky box is connected to your broadband
Hi @JPember99
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
If you still have an issue with your broadband connection then try resetting your broadband router and connection.
Thank you. I will try that.
