Discussion topic: Ovidijus
Message posted on 05 Oct 2025 10:50 AM
Ovidijus
Message posted on 05 Oct 2025 10:56 AM
Re: Ovidijus
@Adomavicius
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
Re: Ovidijus
Hi @Adomavicius "No signal" means your TV is not on the correct HDMI input. Do you mean "No satellite signal"?
