Discussion topic: Our sky is disconnected
Message posted on 30 Sep 2024 10:36 AM
Our sky is not connected and the green light on the sky box is off. We have rebooted. The TH repair guy says that Sky need to attend
Message posted on 30 Sep 2024 11:45 AM
Re: Our sky is disconnected
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
