Discussion topic: Our sky Q mini boxes are not working
This message was authored by PHMCB This message was authored by: PHMCB
We have 4 mini boxes connected to the main box and none of them are showing sky channels it is saying please check your subscription entitles you to view this channel on this box, even though we pay for the extra boxes
Re: Our sky Q mini boxes are not working
Hi @PHMCB
Try a Reset Settings in the main Q box hidden menu.
With Settings highlighted press 0 0 1 Select
PHMCB
Ok thank you I will give this a go
