Discussion topic: Opical output connection is broken
Message posted on 20 Dec 2023 01:19 PM
The optical output connection on sky q box is broken. The cable will not stay connected to provide sound for my home cinema system. Most annoying.
Message posted on 20 Dec 2023 01:25 PM
Re: Opical output connection is broken
You can contact Sky to ask for a replacement box - remember to remove your viewing card and note your recordings will be lost.
Message posted on 20 Dec 2023 02:00 PM
Don't suppose your TV has an optical out?
Message posted on 20 Dec 2023 08:02 PM
Yes it does. In DOLBY ATMOS. My amp doesn't support this. Sky box is in DOLBY DUGITAL and DTS
Message posted on 20 Dec 2023 08:08 PM - last edited: 20 Dec 2023 08:09 PM
@seanwells wrote:Yes it does. In DOLBY ATMOS. My amp doesn't support this. Sky box is in DOLBY DUGITAL and DTS
Hi @seanwells Optical does not support Dolby Atmos. It will be Dolby Digital 5.1 at best.
Message posted on 20 Dec 2023 08:43 PM
Presumably your amp doesn't support hdmi, but you should be able to use the optical out on the TV's instead of Q.
