This discussion topic has been answered Discussion topic: Only one sky channel working
Message posted on 01 May 2024 07:22 PM
Sky mini wouldn't work rest boxes and now only one sky channel is working very strange internet reset as well any idea why thank you
Message posted on 01 May 2024 07:26 PM
Hi @Whispersoul
Reboot the mini as above.
Hi @Whispersoul
