Discussion topic: Only one mini shy Q NO SATELLITE SIGNAL
Message posted on 29 Nov 2024 11:00 AM
I have sky broadband skyward and two mini skyward boxes.
only one mini box won't work it show No Satellite Signal. I have tried all suggested ways to fix this but nothing has worked please help as the one not working is in the living room
Message posted on 29 Nov 2024 11:08 AM
Re: Only one mini shy Q NO SATELLITE SIGNAL
Hi @Wendy1206
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
