6
This discussion topic has been answered Discussion topic: On demand stopped working
This message was authored by: KathyDe
Ever since my Q box went nuts (had to fix it myself since Sky was no help) it's now telling me I have to upgrade if I want to download shows from CI, Sjy History and Sky Crime, just to name a few.  No problem recording or watching live.
Any ideas?
This message was authored by: Laing1 Answer
Re: On demand stopped working
@KathyDe wrote:
Nope, not an HD or SD thing or I wouldn't be able to record or watch live.
@KathyDe so just to confirm  you pay for the HD subscription then ?
have you tried changing the the default download to SD to see if they download in SD it would help in trying to find out whats wrong
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
What did you do to fix it?
Avatar for KathyDe
Too many steps to count, but lots of resets, multiple system resets, multiple reconnection to the Internet (when the Internet was working fine) and reassigning the viewing card.  Took days and now with this issue, seriously looking at Virgin.
@KathyDe Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
Avatar for KathyDe
Avatar for KathyDe
You rock!  Switched the setting and presto, now works.
Thanks!
