Discussion topic: On demand not available
Message posted on 21 Mar 2023 08:23 PM
I have sky signature on sky Q box. When I go to on demand for example the diplomat it shows me it and watch s1 E1 but won't play instead a message at the top of the screen says press red circle to upgrade and watch On demand. When I push the red circle button instead it asks me to upgrade to sky HD!!!! How do I get to watch on demand please
Message posted on 21 Mar 2023 08:26 PM
Re: On demand not available
Hi @Rosemary+p
First check that you are not trying to Download or view HD or UHD content without the Q HD or UHD Subscription pack.
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
