Discussion topic: OXS S3 Sound Bar
Message posted on 30 Oct 2025 06:16 PM
OXS S3 Sound Bar
Hi,
There must be a way to control my OXS S3 Sound Bar with my Sky Q remote (ie. Volume Control).
My sound Bar works fine with its own remote but I would really like to control it with the Sky Q remote.
I tried plugging the optical cable into the sky box (This worked with my old sound bar) but I dont get any sound out at all this way.
There is no code for OXS as far as i can see. (I tried the Philips codes, as surgested on a post on the internet to no avail)
Any help would be very much appreciated.
Message posted on 30 Oct 2025 06:28 PM
Re: OXS S3 Sound Bar
@paul+jeffery wrote:Hi,
What is the make/model of your TV?
If you connect the OXS soundbar to your TV via HDMI ARC and then pair your Sky Q remote to your TV, if you have HDMI CEC control correctly enabled on your TV, the Q remote should control the volume of the soundbar.
Message posted on 30 Oct 2025 06:37 PM
Thanks for replying.
My Samsung TV has a HDMI ARC outlet but my OXS S3 sound bar only has connections for AUX, OPTICAL and COAXIAL 😞
