This discussion topic has been answered Discussion topic: Copy from Sky Q box to Panasonic DVD recorder
Message posted on 30 Mar 2024 01:49 AM
My apologies if this has been asked and answered before. I currently have a Sky+ HD box and it is linked to my Panasonic DVD recorder but I have just been notified that Sky+ will no longer be supported.
Can Sky Q be linked in the same or similar way, if so how can this be done? Also, if I do not upgrade to Sky Q will my current box continue to work or will it just stop working at some future date?
Thanks for reading.
Message posted on 30 Mar 2024 08:17 AM - last edited: 30 Mar 2024 08:18 AM
Hi @Justaviewer in answer to your question "Copy from Sky Q box to Panasonic DVD recorder"
SKYQ is not designed to have an external recorder attached to it, the only output being a HDMI connection to a TV.
SKYQ boxes can record up to six channels at the same time.
Message posted on 30 Mar 2024 08:31 AM
							Re: Copy from Sky Q box to Panasonic DVD recorder
A Sky+ HD box is likely to continue to function for live viewing, recording/playback and on-demand: some interactive functions may cease.
Message posted on 30 Mar 2024 09:11 AM
Sky Q has no SCART output, only HDMI, so if you are currently connecting your +HD box to your Panasonic recorder in this way then you won't be able to do the same with a Q box,
Message posted on 30 Mar 2024 04:06 PM
It is possible to download to a DVD recorder from SkyQ.
However you need a HDMI to SCART converter. You will lose quality but you are able to do it.
Message posted on 21 Apr 2024 05:40 PM
exactly how as have tried this but doesnt work, I have a Mini that think can use somehow
Message posted on 28 Apr 2024 10:05 PM
Hiya, have today connected Sky Q to my Sony DVD Recorder and will put a guide together explaning how have done it
Message posted on 28 Apr 2024 10:37 PM - last edited: 28 Apr 2024 10:41 PM
@maccafan1 wrote:Hiya, have today connected Sky Q to my Sony DVD Recorder and will put a guide together explaning how have done it
Bear in mind any post detailing how to circumvent copy protection will be removed. (2.2k of terms and conditions)
Message posted on 19 May 2024 02:46 PM
I too have a panasonic recorder DVD Player that also edits, I also used to copy from sky to this box then edit, IE cut out adverts etc then record that program onto a disc, but by what Ive read above with sky Q it seems I am no longer able to do that ? Is that correct.
Message posted on 19 May 2024 03:02 PM
@padre wrote:I too have a panasonic recorder DVD Player that also edits, I also used to copy from sky to this box then edit, IE cut out adverts etc then record that program onto a disc, but by what Ive read above with sky Q it seems I am no longer able to do that ? Is that correct.
Generally, yes. Only HDMI output with HDCP.
Message posted on 19 May 2024 05:23 PM
Presumably you are using SCART output to do so: that's an interface nearly half a century old, and was never going to be specified on Sky Q. RCA plug (for analogue component video and stereo audio) is even older.
Message posted on 19 May 2024 08:12 PM
Yes you can but wish could tell you how have done it but was told would get deleted.
Message posted on 19 Nov 2024 12:45 PM
Any chance you confirm your external details as appreciate you cannot confirm how to do this on this forum? Even an email address
Message posted on 19 Nov 2024 03:50 PM
You can output analog composite video from a mini
the results are poor. But then so are DVDs.
Message posted on 19 Nov 2024 04:18 PM
But even then the video can be subject to Macrovision copy protection
