Discussion topic: Not working
This message was authored by: LVJ
Not working
My sky q  box is running really slow and sometimes says there is a technical fault with this channel . My sky q mini is even worse and is not working and will not even bring up to guide just got a circle spinning . Network is good and everything else is working in my house. So can't watch tv on mini and really struggling on main box
Re: Not working
Hi @LVJ
Try a Reset Settings in the  main Q box hidden menu.
Avatar for LVJ
Re: Not working
Thanks but not cured the problem . Tried everything. Still no guide on mini and main box slow . Had them years and no problem till now . Can sky help me ?
Re: Not working
@LVJ wrote:
Can sky help me ?
@LVJ
Give them a call when they open. They will probably guide you through some self help first (like already tried). If it doesn't help they may arrange an engineer appointment.
HAPPY NEW YEAR
