Discussion topic: Not worked since installed
This message was authored by: Cheriton162
Box not connected  , handset  doesn't seem to work , Netflix not connected ,
Avatar for Cheriton162
Error dsu 504 and now 306 and nw316 and MySky 7998
No Netflix. , error messages , don't know if connections are correct , or if remote is working
Re: Not worked since installed
@Cheriton162  Which box did you have installed?
Was originally dish with Q box  , now direct bt line with some sort of new box not connected , can't undue new handset to check batteries , can't get new  Netflix , new landline works , trying an software upgrade , ?
Can you explain your issue in a way that someone can understand without having to physically see your setup
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
This message was authored by: Doc5907
"some sort of new box" ??
Sky stream maybe ?
Sky Q 1TB UHD
LG TV
Sky Mobile
@Cheriton162
As you'd also posted on the sky Q board I've merged your two threads but to be able to help you we need more information particularly you confirming that you have Sky Q?
