Discussion topic: Not recording or downloading
Message posted on 30 Mar 2024 03:22 PM
Sky box not recording all say failed try to download nothing downloading
Message posted on 30 Mar 2024 04:18 PM
Re: Not recording or downloading
Could be a Hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
