Discussion topic: Not getting BBC channels
Message posted on 22 Jan 2024 12:15 PM
I am not getting BBC channels
Message posted on 22 Jan 2024 12:17 PM
Re: Not getting BBC channels
Message posted on 22 Jan 2024 12:24 PM
What happens when you try to go to 101 then?
Message posted on 22 Jan 2024 12:29 PM
@JS151
Any error message ~ for example "no satellite signal"?
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
HAPPY NEW YEAR
