Discussion topic: Not connecting to tv
This message was authored by: finbeau15
Hi,
Can anybody help, I can't get Sky to connect to my TV. I've turned the Sky Q box off and on but still not connecting. I've tried resetting the box and it's just flashing an orange light.
Re: Not connecting to tv
@finbeau15 wrote:
Hi,
@finbeau15 are you seeing any error messages on the screen
also
you do realise your Q box connects to the TV by HDMI cable(im sure you know this)  so the flashing orange light (which is probably the WPS buttn) isnt the problem unless you mean you cant connect your Q box to your broadband router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
