4
This discussion topic has been answered Discussion topic: Not able to see future programmes with the TV guide
This message was authored by: Glyn1956
I have just been pursuaded by Sky to move from Sky + to Sky Q and am frustrated by one thing in particular. With Sky + you were able to use the yellow button to access the TV guide as far as 7 days forward to see what is coming up. This meant you could set a sheduled record in advance whhch was great, for instance, when you were perhaps on holiday and could not set record that day. With Sky Q it seems I can only see what is on today, I can't scroll forward to future days at all. Being a newbee to Q am I just missing something or is this a clear step backwards? Thanks for any advice you  can provide.
Re: Not able to see future programmes with the TV guide
@Glyn1956
To advance a day in the epg once todays programmes are displayed press the fast forward button ️ the number of times you want to get to the day in question,
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
@Glyn1956
Hi @Glyn1956   Try the "?" key, it will tell you everything you wish to know.
Avatar for Glyn1956
Level 0 icon
Daniel, thank you so much for your very prompt assistance. Just tried it and it works! I do think that Sky should include this insruction on their material. I would never have worked it out had you not pointed it out. Thanks again and have a good week end.
@Glyn1956
See this guide
https://www.sky.com/help/articles/using-sky-q-remote
Answered - Go to Answer
