1
This discussion topic has been answered Discussion topic: Non responsive Sky Q box
This message was authored by: Clive81
My Sky Q box is not responding or transmitting any signal
Re: Non responsive Sky Q box
@Clive81
Its always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
@Clive81
