Discussion topic: Nolan the sky controller won’t work
This message was authored by: lauraine+nolan
The sky controls won't work, I have changed the batteries and it still won't work
Re: Nolan the sky controller won’t work
@lauraine+nolan
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well as the above you’ll have a spare.
Hi @lauraine+nolan
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
