This discussion topic has been answered Discussion topic: Noise from sky box
Message posted on 19 Dec 2024 02:52 PM
Message posted on 19 Dec 2024 03:11 PM
Hi thanks for replying with that info. My sky box is sat on its own with full ventilation, I don't have it placed inside a TV unit/cabinet or anything like that same as my boys PlayStation - I keep them free & out in the open on top of the wooden unit so they wont get hot. This noise is new, never done it before. It is only quiet but noticeable. The box isn't hot or anything, it's just a strange noise that has never been there before.
Thankyou for your help
Message posted on 19 Dec 2024 03:02 PM
Re: Noise from sky box
Q has 2 sources of noise - the hard disk and fan.
Hard disk's naturally make a certain amount of whirring and tinkling but should not be excessive.
The fan can work harder (and noisier) if the box is getting hot. Sometimes they can 'stuck' on and a power cycle will fix it.
Ensure the box has sufficient airflow. However, if may get to a point where it needs replacing if excessive.
