Discussion topic: No volume on tV via sky
This message was authored by: aidanbrophy12xxx
Hi All. All of a sudden I have no vomune through my television with sky Q. (TV Volume is fine on Netflix, apps etc) I have reset couple of times but no luck!!! Any help please.
Re: No volume on tV via sky
Reset what? The remote?
edit: oh do you mean no audio at all? What audio output do you have selected in the settings?
Avatar for aidanbrophy12xxx
I have reset the sky q box. None of the settings have changed or been touched. Sky just just has no volume coming through tV.
@aidanbrophy12xxx have you tried removing the HDMI cable and re-inserting it or replacing the cable or if possible try anothe TV with the box
Trying another TV would confirm whether its the box or something else
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@aidanbrophy12xxx
Even though you may get sound form other sources we sometimes find that power off restart of the TV itself cures no sound from SKY Q
Thank you, that's sorted it. Although now my Sky remote doesn't control the TV anymore. Tried pairing it via settings, it's says paired successfully. But it isn't working 🤷‍♂️
Hi @aidanbrophy12xxx
Try completly resetting your Bluetooth remote.
This message was authored by: sp38
I've got the same problem. What was the solution that worked? Was it rebooting the TV? Or was it to do with unplugging the HDMI cable?
This message was authored by: Holmeside
Hi Ive always had to use the TV remote for the volume so I tried the "press 4&6 then 7&9 then 1&3"  and now none of the buttons work on my sky control. VERY frustrating! Can anyone help please?
