Discussion topic: No tvprogrammes
This message was authored by: CP1961
No tvprogrammes
My sky tv is not playing any channels ? What to do
Re: No tvprogrammes
Hi @CP1961   Have you tried a power reboot?
Re: No tvprogrammes
@CP1961
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
