Discussion topic: No tv apps or mini box
Message posted on 10 Jan 2024 01:36 PM
A box working. No apps. No mini box working. Internet is fine. Says I don't have a subscription. £200+ says I do. Please sort this for me. Thank you. Sophie Monk.
Message posted on 10 Jan 2024 01:46 PM
Re: No tv apps or mini box
Try rebooting your main Sky Q box, then when that's up and running again do the same with any mini boxes.
~ press the 🏠 button
Message posted on 10 Jan 2024 01:57 PM
Thanks. It was just a question of time, as I've been away. No idea why the Sky Q box takes 30 minutes to connect to the router, but all good now thanks.
Message posted on 10 Jan 2024 01:58 PM
Glad it's sorted.
