Discussion topic: No sound
Message posted on 31 Dec 2024 03:59 PM
No sound
No sound, randomly just went on the main sky Q box.
reset the tv and the box also, changed the hdmi cable.
Message posted on 31 Dec 2024 04:05 PM
Re: No sound
Was this a reset settings on the Q box?
Reset Settings in the Q box hidden menu.
