Discussion topic: No sky signal
This message was authored by: William110
No sky signal
My brother William Glencross(I am his Power of attorney) has no satellite signal. We have taken the usual measures(unplugging, resetting etc) to no avail.
Re: No sky signal
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
it will likely result in an engineer visit to check the dish (assuming it's not a communal dish)
Re: No sky signal
@William110
If he's seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of the Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It may then give you/him the opportunity to arrange an engineer to check the alignment of your dish. If it doesn’t you/he will need to contact Sky to book an engineer appointment.
If he's connected to a communal dish you need to liaise directly with the building management company / landlord who will have their approved engineers to contact.
It’s worth noting that:
▪️I AM NOT A SKY EMPLOYEE ▪️
