Discussion topic: No sky apps working
This message was authored by: annie2003
No sky apps working
I've got no sky apps working, according to sky there is no issues though.
This message was authored by: Michaela58
Re: No sky apps working
I have the same issue. Saying we are not connected to the internet (we are), broadband and wifi working fine, just not the tv apps
Do you have Sky Q, Sky Glass or Stream ?
I have Sky q
@annie2003 @Michaela58 you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
this can take up to 24 hours to work but usually takes less than that
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
