Discussion topic: No signal
Message posted on 22 Feb 2025 07:29 AM
No signal
Broadband issues and no signal.
Message posted on 22 Feb 2025 07:31 AM
Re: No signal
@Hayley251 wrote:
and no signal.
@Hayley251
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - due to the recent storms there’s still likely to be a significant delay in getting an appointment so it may be quicker to contact a local satellite company but that would be at your own expense.
Message posted on 22 Feb 2025 08:48 AM
Re: No signal
We're better than AI here but do need a little more to go on...
