Discussion topic: No signal
Message posted on 24 Dec 2024 10:03 PM
No signal
Message posted on 24 Dec 2024 10:08 PM
Re: No signal
@Pizza wrote:
Hi @Pizza
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Message posted on 25 Dec 2024 03:02 AM
Re: No signal
Alternatively as your thread title suggests you're seeing a message displaying ”no signal” this tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight and then follow the advice from @oldfella
