Discussion topic: No signal
This message was authored by: Ja30
No signal
I need help, my SKY channel are coming up no signal for the past 7 days. I have rebooted my SKY box almost five times now. But I am still not getting any signal on my box. I rang SKY and was sent this text message to fix the issue myself.
Re: No signal
No signal or no satellite signal?
Re: No signal
@Ja30
If you’re seeing a message displaying ”No signal” it tends to be from your TV, such as possibly not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Whenever a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you’ll need to liaise with your landlord or building management company who deal directly with their approved engineers.
Avatar for Ja30
Level 0 icon
Re: No signal
Hi There,
Thanks for replying, but it's saying no satellite signal. Sorry my mistake.
I have been rebooting my box all week. I have given up. I don't know what else to do.
BW,
Ja30
Avatar for Ja30
Level 0 icon
Re: No signal
The connections ok at back of the box and leading out.
Re: No signal
@Ja30
See my previous post!
