Discussion topic: Have sky q. Main box ok. Mini box keeps sticking during watching. Have updated software alread
This message was authored by: rjb1991
Have sky q.  Main box good.  One mini box keeps sticking when watching tv.  Have performed software update but still sticking
Re: Have sky q. Main box ok. Mini box keeps sticking during watching. Have updated software alrea
Hi @rjb1991
Reboot the mini as above.
