Discussion topic: No signal
This message was authored by: Ana17
No signal
Since a few days i have a no signal  message on W HD and Alibi HD, the W and Alibi and W+ and Alibi + have a signal,  rebooted my q box 3 times , what's the problem  ?
Re: No signal
@Ana17
”No signal” tends to be a message from your TV (in which case check the cables going to the TV).
A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Re: No signal
Looks like your Satellite dish may be slightly out of alignment @Ana17
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-q.
