Discussion topic: No signal
This message was authored by: Steve999
No signal
Tv showing no signal, some sound very broken up. I have switched off at the mains, waited couple of minutes and turned back. HELLO Message appears,
then your screen will go blank. That's it
 Back to no signal.
Re: No signal
@Steve999  No signal is a TV message and may be that you are tuned to Freeview.
If you see a No Satellite sign then that is a dish alignment problem and you would need to call Sky.
