Discussion topic: No signal
This message was authored by: Livvers89
No signal
Hi my tv is showing the following:
NO SIGNAL
1) check your connection and settings source
2) press source on your remote control to select connected source drive
my sky is plugged into hdmi 1 and it's not picking it up
Re: No signal
@Livvers89
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
