Discussion topic: No signal
Message posted on 12 Dec 2023 10:44 AM
No signal
Hi are sky is not working on the tv no error code just snow. I unconnected all cables and re plugged .tried new hdmi lead. Broadband is working. Reset router and skyQ box .still snow on screen
Message posted on 12 Dec 2023 10:53 AM
Re: No signal
@Alison1973 As you have mentioned Sky Q your post has been moved from the Glass/Stream forum as that is for a different TV system.
Message posted on 12 Dec 2023 11:36 AM
Re: No signal
You usually only get snow on terrestrial analog inputs. You need to cycle through the inputs on the Tv until you get to the right HDMI input.
The exception is sometimes a HDCP encryption negotiation failure (which is an HDMI security thing) can produce multicoloured snow but usually it just gives an error. If it's that, shutting everything down and restarting it, TV first, might fix it.
