Discussion topic: No signal selectively
This message was authored by: PeteAC
I cannot get CNN or Classic FM Radio - all other channels are OK.  How can this happen so selectively ?
Re: No signal selectively
@PeteAC
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
hi @PeteAC
In addition to the reply from @Daniel0210  it may be worth noting that both these are on European wide transpnders rather than UK specific targetted  ones and thus slightly weaker here.
CNN is known as one of the first channels that customers with a mis-aligned dish seem to notice
Avatar for PeteAC
Thanks for that info
