Discussion topic: No signal post storm
This message was authored by: Eilidh5
My sky Q hasn't had signal since the storm. How do I get the signal back?
Re: No signal post storm
You'll probably need your dish realigned.
Either call Sky (it could be several weeks before they can come) or pay a local specialist.
@Eilidh5
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - as stated by @PandJ2020 there’s still likely to be a significant delay in getting an appointment. It may be quicker to contact a local satellite company but that would be at your own expense.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
