2
This discussion topic has been answered Discussion topic: No signal on ITV
This message was authored by: Whiskers70
No signal on ITV
I don't get it my bbc channels are fine as are the plus 1 channels but when I put ITV, channels 4 & 5 and certain sky channels it works fine for about 30 seconds then the picture breaks up and I get the blue screen saying problem with my satellite signal and then the screen goes black. How can it be my signal if ITV+1 is fine. It's been doing this for about 3 weeks now. Has anyone else had the same problem?
This message was authored by: oj01 Answer
Re: No signal on ITV
@Whiskers70 Different channels are on different transponders. If you're dish is slightly misaligned it can, therefore, affect some channels but not others.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Hi @Whiskers70
Could be an issue with your dish alignment or LNB.
It it continues best to contact Sky for an Engineer to check.
