Discussion topic: No satelllite signal
This message was authored by: Margaret141
TV showing  No Satellite signal, started buffering during storm on Friday, no signal since then despite calm weather since then and following all online instructions to no avail. I think dish requires checked onsite. Thanks
Re: No satelllite signal
@Margaret141
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
3 - Due to the recent storms there’s likely to be a significant delay in getting an appointment. It may be quicker to contact a local satellite company but that would be at your own expense.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by: Chadfield73
I also have this issue. Was it resolved in anyway?
@Chadfield73
Post 2 applies to you too. Once out of alignment you'll need an engineer to fix it.
