Discussion topic: No satellite
Message posted on 09 Dec 2024 08:12 PM
No satellite
Hi
Message posted on 09 Dec 2024 08:18 PM
Re: No satellite
A one word post doesn't help us to help you but based on the thread title firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 09 Dec 2024 08:24 PM
Re: No satellite
Hi @Rou1 Just checking that you know that this is a public community forum, it is not a live chat.
