Discussion topic: No satellite signal
This message was authored by: Rudi11
No satellite signal
On numerous occasions my sky box will randomly show on tv "no satellite signal" whilst in the process of watching something. This is becoming an ongoing problem can anyone help. Sky have not been great helping. Makes you wonder the amount of money spent a month to watch tv and not really getting your moneys worth.
Re: No satellite signal
Dish needs re-aligning
or there's a tree in the way
is this your dish or communal?
@Rudi11
Why, what have Sky said or done when you've reported this?
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
