Discussion topic: No satellite signal
This message was authored by: joannemcgonigle
No satellite signal
My main sky box and all sky mini boxes all say no satellite signal
Re: No satellite signal
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@joannemcgonigle
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
