Discussion topic: Sky q box no satellite signal
Message posted on 28 May 2025 09:04 AM
Message posted on 28 May 2025 09:42 AM
							Re: Sky q box no satellite signal
@tara12345 wrote:
My sky q box has no signal have checked all cables and also turned sky box off for 3 minutes still no joy
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Message posted on 28 May 2025 10:21 AM
@tara12345
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a  “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
