Discussion topic: No satellite signal
Message posted on 03 Feb 2025 05:15 PM
No satellite signal
Our sky Q hasn't worked since the storm.
No Satellite signal
We have a satellite dish
Who do I contact to get this sorted please.
Message posted on 03 Feb 2025 05:26 PM
Re: No satellite signal
No Satellite signal
hi @Patricia31
As you I think you suspect, following the storms, it is quite likely that the dish has slightly moved & needs re-aligning
Please see the following page that covers a few problems including no Signal - if you follow the link through and still have problems (which is quite likely after the storms) then you should find a link to book an engineer if you have your own dish
https://www.sky.com/help/articles/sky-q-picture-problems
Note after the storms & with the reduction in number of engineers over the last few years then lead times for an apointment may be several weeks
If you have a communal system you may have to contact your building manageme
