Discussion topic: No satellite signal
This message was authored by: Denise9
No satellite signal
I have no satellite signal so cannot get any channels only BBC ITV and Channel 4. I am due to swap over to Sky glass next Saturday 21 October 2023.
Re: No satellite signal
@Denise9  Your post has been moved to the Sky Q forum as this issue has nothing to do with Sky Glass.
A No satellite signal is complaetely unrelated to you getting Glass as it's more likely this is a dish issue rather than a subscription issue.  Have you tried rebooting your Sky Q box?
@Denise9
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer (if you think it worth it for less than a week), to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
