Discussion topic: No satellite signal
This message was authored by: SandraStaunton
No satellite signal
No satellite signal notice appearing on my screen. Service Check is showing everything working. Its been 2 days and still not working.
Re: No satellite signal
@SandraStaunton
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
▪️I AM NOT A SKY EMPLOYEE ▪️
