Discussion topic: No satellite signal in my new Q box
Message posted on 11 Jul 2025 08:49 PM
I've been sent a new sky Q box as my old one kept freezing now having connected my new one the system is telling me I have no satellite signal and there is no engineer available until Monday
Message posted on 11 Jul 2025 08:53 PM
Re: No satellite signal in my new Q box
Getting an engineer out on the next working day is extremely lucky so hopefully you took that appointment.
Message posted on 11 Jul 2025 08:54 PM
hi @Scouse2
Do you have your own dish or are fed by a Communal System ?
If you are fed by a communal system then the chances are that the LNB type is set incorrectly
You need to check/change the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
