Discussion topic: No satellite sign
Message posted on 30 Apr 2025 04:02 PM
No satellite sign
No signal
Message posted on 30 Apr 2025 04:04 PM
Re: No satellite sign
@Damian23
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
