Discussion topic: No satalite signal
This message was authored by: Snuffy
No satalite signal
my main box says no satalite signal my mini box isnt picking up anything.
My friend around the corner is having the same issue.
Re: No satalite signal
@Snuffy
Any message displaying “no satellite signal” relates to your Sky Q box. You and your friend are coincidentally seeing the same so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
