Discussion topic: Tv not working says satellite signal
Message posted on 22 Jul 2024 02:17 PM
Sky tv not working says satellite signal
Message posted on 22 Jul 2024 02:29 PM
Re: Tv not working says satellite signal
Any message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
